Re: real men port cast iron heads
[Re: Joesixpack]
#1015371
06/19/11 05:32 PM
06/19/11 05:32 PM
Posts: 11,915 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
I did a pair of 906s sitting on top of a garbage can in an alley,when i worked at Borowskis back in 87,went to a guy in Kankakee or Bourbanais named Alan, went on a street racer. were not pretty but,did not hit any water jackets,2.14/1.81 valves,epoxied some spring cups for big triples,intake ports ended up not fitting any known or avail gasket....had to make them..they ported the intake to match,worked great on a .060 440 with 4.00 stroker crank...i think it was around 511-512 cubes...real old school as that is what we knew back then.
[Re: Joesixpack]
#1015373
06/19/11 09:00 PM
06/19/11 09:00 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
wow Mike those 915 Js are SWEET!got a pair of bare virgins i will send to ya,make em look like that!LOL worth at least two tenths!
Thanks Joe!!!!! But I cant take the credit. A real good friend in Ky ported and flowed them for me. He is VERY reasonable and GOOD!!!! He said that they were the BEST stock smallblock head he has done. They flowed pretty well too.
[Re: Crizila]
#1015374
06/19/11 09:21 PM
06/19/11 09:21 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Dwayne and I did some Equest heads together, and you'd be surprised at what they responded to, what they didnt like, and what made them go backwards. Some of standard cylinder heads mods, didnt respond well. Some very very simple things worked excellent. Its not always bigger and hawged out is better. Shiny doesnt mean fast.... ![](/ubbthreads/images/graemlins/laugh2.gif) ...they are great little heads in my opinion, and can be made to work very well with MINIMAL work.
RIP Monte Smith
