Re: real men port cast iron heads [Re: 440CIVIC] #1015361
06/18/11 04:09 PM
06/18/11 04:09 PM
Merrill, WI
440CIVIC Offline
440CIVIC  Offline
Merrill, WI
CNC milled exhaust port
Re: real men port cast iron heads [Re: 440CIVIC] #1015362
06/18/11 04:11 PM
06/18/11 04:11 PM
Merrill, WI
440CIVIC Offline
440CIVIC  Offline
Merrill, WI
After the grinder
Re: real men port cast iron heads [Re: roadhazard] #1015363
06/18/11 04:58 PM
06/18/11 04:58 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
My Junk
Just a little time in these
Roadhazard; how did you get those roughed up like that? I used 50 grit, and slowed the die grinder way down, but my intakes seem a little too smooth to me.
Re: real men port cast iron heads [Re: 340B5] #1015364
06/18/11 10:19 PM
06/18/11 10:19 PM
Down under
slantman Offline
slantman  Offline
Down under
I'll join in too.
Here's my 518M head, though not ported by me.
Re: real men port cast iron heads [Re: slantman] #1015365
06/19/11 01:02 AM
06/19/11 01:02 AM
Central NC
gch Offline
gch  Offline
Central NC
Smart men pay others to do it.........
Re: real men port cast iron heads [Re: gch] #1015366
06/19/11 02:46 AM
06/19/11 02:46 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Smart menpay others to do it.........
Fastest 300
Re: real men port cast iron heads [Re: Crizila] #1015367
06/19/11 09:24 AM
06/19/11 09:24 AM
Central NC
gch Offline
gch  Offline
Central NC
Re: real men port cast iron heads [Re: Crizila] #1015368
06/19/11 09:30 AM
06/19/11 09:30 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Re: real men port cast iron heads [Re: roadhazard] #1015369
06/19/11 11:59 AM
06/19/11 11:59 AM
Australia
Charger VJ RB Offline
Australia
Wow never seen anything like that before, what do those suckers flow?
RB XE274H Q-850
Re: real men port cast iron heads [Re: Charger VJ RB] #1015370
06/19/11 05:23 PM
06/19/11 05:23 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
wow Mike those 915 Js are SWEET!got a pair of bare virgins i will send to ya,make em look like that!LOL worth at least two tenths!
Re: real men port cast iron heads [Re: Joesixpack] #1015371
06/19/11 05:32 PM
06/19/11 05:32 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
I did a pair of 906s sitting on top of a garbage can in an alley,when i worked at Borowskis back in 87,went to a guy in Kankakee or Bourbanais named Alan, went on a street racer. were not pretty but,did not hit any water jackets,2.14/1.81 valves,epoxied some spring cups for big triples,intake ports ended up not fitting any known or avail gasket....had to make them..they ported the intake to match,worked great on a .060 440 with 4.00 stroker crank...i think it was around 511-512 cubes...real old school as that is what we knew back then.
Re: real men port cast iron heads [Re: Crizila] #1015372
06/19/11 06:29 PM
06/19/11 06:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I did my W-2s... didnt go crazy but they went 305 cfm
Re: real men port cast iron heads [Re: Joesixpack] #1015373
06/19/11 09:00 PM
06/19/11 09:00 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Thanks Joe!!!!! But I cant take the credit. A real good friend in Ky ported and flowed them for me. He is VERY reasonable and GOOD!!!! He said that they were the BEST stock smallblock head he has done. They flowed pretty well too.
Re: real men port cast iron heads [Re: Crizila] #1015374
06/19/11 09:21 PM
06/19/11 09:21 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Dwayne and I did some Equest heads together, and you'd be surprised at what they responded to, what they didnt like, and what made them go backwards. Some of standard cylinder heads mods, didnt respond well. Some very very simple things worked excellent. Its not always bigger and hawged out is better. Shiny doesnt mean fast.... ...they are great little heads in my opinion, and can be made to work very well with MINIMAL work.
RIP Monte Smith
Re: real men port cast iron heads [Re: CompWedgeEngines] #1015375
06/19/11 09:39 PM
06/19/11 09:39 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
You "forgot" to share any pertinent info - not to mention any pics. Simple ( usually means obvious ) things always show big improvement when you are starting with A stock casting. "Shiny doesn't mean fast" is a true statement.
Fastest 300
Re: real men port cast iron heads [Re: Crizila] #1015376
06/19/11 10:46 PM
06/19/11 10:46 PM
Get-X Offline
Get-X  Offline
My 915 castings after being freshened up this year with new 2.14 1.81 valves, springs, guides and valve job. They're mildly bowl and match ported for street use on the GTX.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: real men port cast iron heads [Re: Crizila] #1015377
06/19/11 11:14 PM
06/19/11 11:14 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
On the subject of port finish (shiny), that argument has been around sice Joe M. was porting heads for Mazmanian. IMO, port finish has little to do with flow ( changing the boundary layer / fuel drop-out, etc.). Those things are driven by port shape and velocity. I like smooth ( shiny if you will )intake ports for the same reason I make the exhaust ports and backs of the valves smooth. They just stay cleaner longer. I'm sure there are a million professional porters out there that will disagree with me on this, but - there has to be something that seperates the amateurs from the professionals.
Fastest 300
Re: real men port cast iron heads [Re: CompWedgeEngines] #1015378
06/20/11 12:16 AM
06/20/11 12:16 AM
SoCal
Brian Hafliger Offline
SoCal
This post is worthless without pics!
Brian Hafliger
