Re: did i hur t the engine
[Re: modified1090]
#1011839
06/12/11 08:55 PM
06/12/11 08:55 PM
Posts: 43,200 Bend,OR USA
Cab_Burge
do you have a leak down guage or compression gauge? If so pull all the plugs and do a test first, if there all good and there are no obvious leaks or holes in the block start it up and see how it idles ands runs. Defineitely check the trans rear sprague and converter for your own piece of mind
[Re: Cab_Burge]
#1011840
06/12/11 10:30 PM
06/12/11 10:30 PM
dartman366
Mt. Vernon, Ohio
do a leak down, pull the valve covers and check the spring's and push rod's then start it up and listen carefully, and then pull the oil filter and look it over carefully,, if you had a 7000 chip in it, then you probably didn't hurt anything, but if it makes a unfamiliar noise or shows crap in the filter then you know what you need to do, keep us informed.
[Re: BLONDE BARRACUDA]
#1011843
06/13/11 12:53 AM
06/13/11 12:53 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Pull the covers and run lash.. Should be common practice, and indicate possible damage. Looks good fire it up.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
