did i hur t the engine #1011835
06/12/11 12:10 PM
06/12/11 12:10 PM
madison, ohio
modified1090 Offline OP
madison, ohio
yesterday on my 3rd time run i poped the driveshaft on the launch. engine hit the rev limiter i didn't see how high the tach went but assume it may have gone over the 7k i had in it.
now my first response after the deal was to put my spare short block and the backup trans in the car before going back out.
i am still going to do the trans and send the converter for further inspection, but what about the engine. if i pull the push rods and check for straightness and maybe measure the end play on the crank to check the thrust bearing, do you guys think i need to pull the engine?
Re: did i hur t the engine [Re: modified1090] #1011836
06/12/11 12:11 PM
06/12/11 12:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is the engine running differently now than before this happened ?
Re: did i hur t the engine [Re: JohnRR] #1011837
06/12/11 12:14 PM
06/12/11 12:14 PM
madison, ohio
madison, ohio
i shut it off right away and have not started it since
Re: did i hur t the engine [Re: modified1090] #1011838
06/12/11 12:21 PM
06/12/11 12:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would doubt you hurt it... thats why you have the
rev limiter... fire it up and check it out
Re: did i hur t the engine [Re: modified1090] #1011839
06/12/11 08:55 PM
06/12/11 08:55 PM
do you have a leak down guage or compression gauge? If so pull all the plugs and do a test first, if there all good and there are no obvious leaks or holes in the block start it up and see how it idles ands runs. Defineitely check the trans rear sprague and converter for your own piece of mind
Re: did i hur t the engine [Re: Cab_Burge] #1011840
06/12/11 10:30 PM
06/12/11 10:30 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
do a leak down, pull the valve covers and check the spring's and push rod's then start it up and listen carefully, and then pull the oil filter and look it over carefully,, if you had a 7000 chip in it, then you probably didn't hurt anything, but if it makes a unfamiliar noise or shows crap in the filter then you know what you need to do, keep us informed.
Re: did i hur t the engine [Re: dartman366] #1011841
06/12/11 10:42 PM
06/12/11 10:42 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
What kind of a engine do you run? I shift my 440 stroker at 6800 , limiter set at 7200. I've broken the trans a few times and bounced off the limiter with no ill effects.
Re: did i hur t the engine [Re: modified1090] #1011842
06/12/11 11:32 PM
06/12/11 11:32 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
Ive heard that the actual rpm is a couple hundred under the rev chip you are useing, not sure why you are thinking you hurt anything, good luck anyway
Re: did i hur t the engine [Re: BLONDE BARRACUDA] #1011843
06/13/11 12:53 AM
06/13/11 12:53 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Pull the covers and run lash.. Should be common practice, and indicate possible damage.
Looks good fire it up.
