Quote: If you look at the proper position of the installed slinger it does what it designed to do. It cups over the seal area keeping excess oil from the seal area.
Some of youz guyz are missing the point .... the minor secondary "job" of this part is to "protect" the seal from excess oil.....
.... the main job is is to SLING oil up and around the timing chain and gears..... HENCE the name ...
