If you guys are saying a low to mid 10 I must be missing something. I purchased a complete Indy motor 415 ci it has all the good stuff except for a full port on the heads it has a stage 1 port/matched gasketed intake and heads. Its a 3200 lb car from what I can figure, I run a cope 904 5000 stahl on a 28 x 10 slick, 456 rear gear best is 10.82.
Now I think i have been going wrong with the front of the car I have now a really good front end alignment and have taken about 30 lbs out of the car this winter. I want another 30 or 40 out buy spring.
So where am I going wrong and my sixtys are real good and consistant?? Not to hijack but not sure where I am going wrong.
but his motor is like my brothers setup and his is a 11.30 all day any day car very cosistant.
let me know what you think and your results
it's all in the combination, I had my stock stroke 360 with indy heads in my sons 3250lb challenger bone stock suspension running 11.0s on a 2bbl carb. same motor runs 10.40s in my challenget at 3000lbs.
