Second, remember that I run a 904 with a low gearset, wich make a 3.91:1 act like a 4.30!
You would have been better off changing the rear gear instead of the low gearset. A drag race engine doesn't like the big rpm drop on the gear change. Make sure you get a good converter.
BB, TT5,Procharged 3300lb Street Car 4.79/154
