I think with the right converter, trans and gear that the combo should be good for low 10s. My brothers car sounds quite similar to what you are explaning and it goes 10.50s @ 125 with a 28X9 Hoosier slick. You heads are bigger, cam seems more aggressive and the cubes are more than ours...I think you will go faster than 10.50s.
I figured between 535 and 550 HP. Should go 129 MPH+ @ 3300 lbs.
