Re: Help picking a cam
[Re: Verga]
#927467
02/13/11 05:00 PM
02/13/11 05:00 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
Since you said budget build, i'm guessing you may be using the stock rockers. If so, i've had good luck with the old Comp 292 Magnum hyd. .030 440 8.5 comp, 906s pocket ported when i was 20yo and didn't know what i was doing(still don't), Torker,750dp, 10 in GER stalled about 3800, 3.23s, 28 x9 slicks, 68 Satellite street car all steel except for 6 pak hood. 12.35 at 106, 1.69 60 ft. Cam has been in for about 25 years and hasn't gone flat yet in spite of me not always changing the oil as often as i should. Car sometimes sits for months and then might be driven almost every day for a while.
Ive actually got some 1.6 rockers.
What RPM do you shift that cam?
