Too darn hot here to do much of anything. 104 for the last few days and 103 thru the weekend. Been breaking heat records for a month too. Then add the humidity! My metal shop is a furnace in the worst way. No rain in months.
Engine is complete and sitting in the car but it has to come back out so I can wrap the headers and make my plug wires. My pops dropped it in cause he needed the picker. Put a new throwout bearing in the trans and changed lube, its ready to go back in. I have a few days in the fuel system that needs to be finished and then the 2 MSD boxes, A1000 fuel pump and the Aeromotive pump controller have to be wired up. Then all the boost signal lines. I am hesitant to run it until I can purchase a Innovative afr/wideband setup.
Just need it to cool down a bit so I can get back to tinkering with it.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
