Re: Indy 440-1 users come on in!
[Re: TheOtherDodge]
#854653
11/16/10 06:12 PM
11/16/10 06:12 PM
Posts: 4,074 Mo.
racerx
Mo.
My 498 combo:
-1 home ported Indy intake with stock 1050 12:1 compression Scott Brown solid roller 259/265, .640/650, 112 lsa
I made about 720 hp based on ET and weight.
Just curious what weight,et.,car ?
On motor only, in a 72 Challenger with 4000 converter, foot brake, 4.30 gear with 30" slick, through the mufflers weighing a tad under 3500 lbs, I went 9.87 @ 137. I didn't run it much on motor passes (like Monte ) because I set it up for nitrous, so Im sure if left a lot of ET on the table not doing tuning. I shifted at 6800 and crossed at 6900.
Pretty much the same setup but at 3350 with a 4800 conv.on 10.5w's with a best of 9.67@137
