Quote: My old cam was a 283 @ .050", .683" lift single pattern. Naturally aspirated pump gas 4.5" x 4.15" 528, 11:1, aluminum block, home ported heads with 2.25" intake valves, Indy single plane with a dominator, 2" primary headers and 3" dual exhaust with mufflers. 781 hp at 6600 rpm, 704 ft-lb at 5000. Run 9.69/142.5 in a 3370 lbs in a street car with SS springs and DOT tires.
looks like a nice combo!
seems most on here like the 280@50 and about .720ish lift range (as an average so far)
