Quote: Just drove mine to the local 1/8 mile track last night, which is only about 20 miles each way. I'm sorting out a new combo and only hooked on one pass (where I took off in 2nd gear). Went 6.42 @ 113.47 with only a 1.602 60' time. 100% factory interior, drag radials, exhaust, all steel 70 Charger. Not the quickest thing out there, but not many cars around here drive to and from the track.
That's pretty good MPH in the 1/8 work on those 60's and all is Good.
It has potential. I did leave out that it has a Procharger. The car was previously a N/A car that went 6.71 @ 101.5 with a 1.44 60' All I did was swap head gaskets and the cam when I threw on the blower. I'm still tuning as last night was the first outing with the setup, but I see 6.1X @ 115 as a real possibility. I need to learn to read plugs better but my wideband is saying I'm pretty rich. I'm only running 8-9 PSI as well.
