The problem with crimp connections is they are "generally" exposed to the weather (they are not sealed) so they will start to corrode between the wire and the connector & cause more resistance which is more heat and possible fire...
Plus they are not going to last that long before they start corroding and becoming "somewhat" faulty...
If you solder crimp connections the solder helps seal them from the weather and makes a better connection.
