i just found a pic, i also installed fuses, newer type you can just use female spade connectors on them, and you can see the jumpers/wires from the factory harness, i also just used male/female spade connectors. It's ugly, but it works, i could relocate everything under the battery but I've been too lazy and too busy The third relay is for my dukes horn.....
