from what i could tell at the parts store the /6 and small block springs are the same, my truck with /6 springs and a big block is way too soft in the front. im planning on trying stock height 3/4 ton springs
if i were you id install the 3/4 springs at stock height and check if that corrects your lean issue. then remove and trim as you see fit
