Re: Ray Barton 528 failure what to look for, what happened
[Re: ChrisDavis]
#771319
08/29/10 04:08 PM
08/29/10 04:08 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I will be switching to a solid roller cam if I can locate lifters that will survive on the street.
No problem there. Just have Lunati or your favorite cam company grind you a mild street roller profile (something in the .590-.600 range, 110 lobe separation, 240 @ 050 lift) and run a lighter spring (190 on the seat and 450 open)or a beehive spring. Any lifter/spring will last a long time, your less likely to smoke exhaust push rods, and it'll make plenty o power (mine made 650@6500rpm). Keep your oil pressure around 30psi at idle.
Set the end play up for around .003-.005" so the cam doesn't bump around alot as this beats the hell out of the oil pump drive. It also keeps the ignition timing rock steady.
If you want the specs I can dig them up.
Entire Thread
ChrisDavis
08/11/10 03:59 PM
Pat_Whalen
08/11/10 04:17 PM
ademon
08/11/10 04:19 PM
ademon
08/11/10 04:21 PM
RodStRace
08/11/10 04:35 PM
540challenger
08/11/10 04:43 PM
moper
08/11/10 04:45 PM
ChrisDavis
08/11/10 04:53 PM
stumpy
08/11/10 04:58 PM
ChrisDavis
08/11/10 04:59 PM
64Post
08/11/10 05:06 PM
540DUSTER
08/11/10 08:59 PM
prochargedhemi
08/11/10 09:18 PM
ZIPPY
08/11/10 09:30 PM
Challenger 1
08/11/10 09:54 PM
ChrisDavis
08/11/10 09:57 PM
Challenger 1
08/11/10 09:59 PM
DaveRS23
08/12/10 02:16 AM
JohnRR
08/11/10 09:11 PM
bboogieart
08/11/10 09:13 PM
ChrisDavis
08/11/10 04:20 PM
torkrules
08/12/10 02:08 AM
hemigod426
08/12/10 02:20 AM
ChrisDavis
08/12/10 02:53 AM
DaveRS23
08/12/10 03:16 AM
kz5rt2
08/12/10 03:44 AM
SomeCarGuy
08/12/10 04:08 AM
hemigod426
08/12/10 04:12 AM
torkrules
08/12/10 01:46 PM
feets
08/12/10 03:45 PM
torkrules
08/12/10 08:39 PM
ChrisDavis
08/13/10 03:25 PM
tboomer
08/13/10 03:30 PM
Challenger 1
08/13/10 04:07 PM
HPMike
08/13/10 04:23 PM
KD800X
08/13/10 04:48 PM
Challenger 1
08/13/10 05:16 PM
ChrisDavis
08/13/10 05:49 PM
torkrules
08/13/10 05:53 PM
HPMike
08/13/10 06:02 PM
Mopar_Country
08/14/10 12:58 AM
tboomer
08/13/10 06:05 PM
Dodgeguy101
08/13/10 11:11 PM
SSAAHemiFan
08/13/10 11:30 PM
stumpy
08/14/10 12:20 AM
joewhite440
08/29/10 12:52 AM
Challenger 1
08/14/10 01:20 AM
ChrisDavis
08/28/10 11:43 PM
SomeCarGuy
08/28/10 11:48 PM
hemigod426
08/29/10 12:08 AM
Commando1
08/29/10 01:46 PM
srt
08/29/10 03:40 PM
quick77rt
08/29/10 04:03 PM
torkrules
08/29/10 08:08 PM
Challenger 1
08/29/10 03:38 PM
Vert
08/31/10 01:35 PM
GODSCOUNTRY340
08/31/10 03:40 PM
imfixinmopars426
08/31/10 07:12 PM
64Post
08/31/10 08:54 PM
Re: Ray Barton 528 Valve Train Oiling
ChrisDavis
09/29/10 09:37 PM
torkrules
09/30/10 01:35 AM
64Post
09/30/10 01:39 AM
ChrisDavis
10/18/10 06:33 PM
Challenger 1
10/18/10 06:35 PM
torkrules
09/01/10 01:54 AM
Twostick
09/30/10 03:53 AM
JohnRR
10/18/10 08:12 PM
ChrisDavis
10/18/10 09:15 PM
68X426
10/18/10 10:24 PM
ChrisDavis
10/18/10 10:54 PM
gdonovan
08/31/10 08:50 PM
Challenger 1
08/31/10 09:09 PM
hemigod426
08/31/10 10:36 PM
gdonovan
08/31/10 11:07 PM
Vert
09/01/10 02:22 AM
Vert
09/15/10 02:52 AM
