The exhaust is relatively quiet. However the Ray Barton rocker arms and solid lifters are not. The lifter noise is all I hear under the hood and it sounds the same as it always has.
Wondering about the valve lash after reading this, who set the valve lash? Have you checked since this problem popped up? Noisey rocker arms arn't normal, imho.
Thanks for the update, sorry about your engine.
When I read what you said about valve train noise it made it sound like the lash was not set right. It's easy to it get wrong, Sorry again.
