That there I find interesting...I got this from a well known racer..There are two Moroso pans that are advertised as 7 quarts...One is actually 6!! Why they sell it as a 7 quart pan is beyond me. Also why would Barton tell you to only run 6 quarts? When you changed oil did you put a 1/2 quart into the filter then top it off? Did the dipstick read at the full mark? What pickup did it have on it??
I have used a lot of those pans on engines over the years. I never knew that! All the ones I put on took 7 Quarts in the pan and one for the filter. Always read the full mark on the Dipstick.
I guess you are never to old to learn !
