Re: Ray Barton 528 failure what to look for, what happened
[Re: RodStRace]
#771271
08/11/10 12:43 PM
08/11/10 12:43 PM
Posts: 2,826 NY usa
540challenger
NY usa
Do you have a teenage son?
Sorry to hear your engine is not well. I'd be very tempted to pull it rather than just pull the pan and check bearings. A clean engine is a happy engine and all that stuff is inside. I would pull the dist. and check the gear. Brass shavings.....
Pull the dist. Check the gear. I have had a few customers that the gear would wear. In turn it changes the speed since now the timing is change and with a lower idle the oil psi will drop. Sometimes does bronze gears last forever other times you almost want tpo change them every oil change. If it is the gear, in the future check the timing every so often when it starts to change the gear is wearing.
Entire Thread
ChrisDavis
08/11/10 03:59 PM
Pat_Whalen
08/11/10 04:17 PM
ademon
08/11/10 04:19 PM
ademon
08/11/10 04:21 PM
RodStRace
08/11/10 04:35 PM
540challenger
08/11/10 04:43 PM
moper
08/11/10 04:45 PM
ChrisDavis
08/11/10 04:53 PM
stumpy
08/11/10 04:58 PM
ChrisDavis
08/11/10 04:59 PM
64Post
08/11/10 05:06 PM
540DUSTER
08/11/10 08:59 PM
prochargedhemi
08/11/10 09:18 PM
ZIPPY
08/11/10 09:30 PM
Challenger 1
08/11/10 09:54 PM
ChrisDavis
08/11/10 09:57 PM
Challenger 1
08/11/10 09:59 PM
DaveRS23
08/12/10 02:16 AM
JohnRR
08/11/10 09:11 PM
bboogieart
08/11/10 09:13 PM
ChrisDavis
08/11/10 04:20 PM
torkrules
08/12/10 02:08 AM
hemigod426
08/12/10 02:20 AM
ChrisDavis
08/12/10 02:53 AM
DaveRS23
08/12/10 03:16 AM
kz5rt2
08/12/10 03:44 AM
SomeCarGuy
08/12/10 04:08 AM
hemigod426
08/12/10 04:12 AM
torkrules
08/12/10 01:46 PM
feets
08/12/10 03:45 PM
torkrules
08/12/10 08:39 PM
ChrisDavis
08/13/10 03:25 PM
tboomer
08/13/10 03:30 PM
Challenger 1
08/13/10 04:07 PM
HPMike
08/13/10 04:23 PM
KD800X
08/13/10 04:48 PM
Challenger 1
08/13/10 05:16 PM
ChrisDavis
08/13/10 05:49 PM
torkrules
08/13/10 05:53 PM
HPMike
08/13/10 06:02 PM
Mopar_Country
08/14/10 12:58 AM
tboomer
08/13/10 06:05 PM
Dodgeguy101
08/13/10 11:11 PM
SSAAHemiFan
08/13/10 11:30 PM
stumpy
08/14/10 12:20 AM
joewhite440
08/29/10 12:52 AM
Challenger 1
08/14/10 01:20 AM
ChrisDavis
08/28/10 11:43 PM
SomeCarGuy
08/28/10 11:48 PM
hemigod426
08/29/10 12:08 AM
Commando1
08/29/10 01:46 PM
srt
08/29/10 03:40 PM
quick77rt
08/29/10 04:03 PM
torkrules
08/29/10 08:08 PM
Challenger 1
08/29/10 03:38 PM
Vert
08/31/10 01:35 PM
GODSCOUNTRY340
08/31/10 03:40 PM
imfixinmopars426
08/31/10 07:12 PM
64Post
08/31/10 08:54 PM
Re: Ray Barton 528 Valve Train Oiling
ChrisDavis
09/29/10 09:37 PM
torkrules
09/30/10 01:35 AM
64Post
09/30/10 01:39 AM
ChrisDavis
10/18/10 06:33 PM
Challenger 1
10/18/10 06:35 PM
torkrules
09/01/10 01:54 AM
Twostick
09/30/10 03:53 AM
JohnRR
10/18/10 08:12 PM
ChrisDavis
10/18/10 09:15 PM
68X426
10/18/10 10:24 PM
ChrisDavis
10/18/10 10:54 PM
gdonovan
08/31/10 08:50 PM
Challenger 1
08/31/10 09:09 PM
hemigod426
08/31/10 10:36 PM
gdonovan
08/31/10 11:07 PM
Vert
09/01/10 02:22 AM
Vert
09/15/10 02:52 AM
