If Pettis built it, and you say he did.. Then you got to figure that it makes conservatively 750 ponies. In a 2700# car it could possibly go in the 8's.. Possibly.. Not likely. However, it more likely makes more than 750hp though. Probably closer to 800hp.
You have been barely in the 9's in much better air that you will be in at Fontucky in the summertime..
I have to say that even running poorly, and if the Nova has a Glide, it should easily run mid 9's..
I would say not to pump your chest out too much.. But it's not a lock that he beats you.
