Next time you see the car look at the angle of the ladder bars, if they are pointed up I give it to you... as he will most likely po-go off the line.. but you better be on your game ... hopefully he put all his money in the motor and not the chassis as in good shocks and the set up .... good luck(as someone said already you should have said next week)
