Lining up the marks should be ok.
This is the most ignorant statement I think I've ever witnessed on this board.
Think the 440 that I "lined up the marks" on with the MP .528 mechanical and Cloyes true roller that was retarded 8* would've run right?!
Look folks, it's an easy procedure and it's not for getting that last tenth or 2 out of the motor. It's to assure that the parts were stamped/ground/assembled correctly. Spent the effort and the 15 minutes to do it right! For the money you spend on the rest of the motor isn't it worth it to make sure you don't make it into garbage on startup?!
