Quote: I was sure the pump in my buddies truck had 6 lines in a row on top. It's a 1998 24V IIRC and it's electronic because he has an Edge box on it. If it has the pump in the link on it I obviously did not know from whence I spoke. Thanks for the link.
Kevin
Boy you are really mixed up and dont know the cummins diesels to well. 6 in a row is the P series and is factory on the 12 valve motors. It is NOT electronic so no edge box. It could be an early 98 truck but would not be a 24 valve. The pump in the link ia a VP44 and is 24 valve 98.5 through 2002.
