Quote: My 440 ran 190 on hottest days. Installed new cam,Installed new cam,Installed new cam,Installed new cam, and went to 440 source water pump housing and pump. Car runs hot now and summer hasn't started. Will adding electric fan help or do i have to dump the 440 source parts?
Which cam did you install when you started having over heating problems? I guess that's where the term "just installed a HOT cam" came from You've done everything but change the cam or did I miss that part?
Just my but I'm betting the cam is the "source" of all of your high temp problems.
