Quote: Installed the Milodon pump and temp droped 20 to 30 degree's. The 440 source pumps are junk. Even worse when used with there houseing. Cars runs at 185 steady now 190 in stop and go traffic. Now when you rev it up a bit you can see the water really moving in the rad.
Told ya the pump was junk The 440 Source pump housing wouldn't be my first choice either. It does work OK, but there are better products available for a similar price
440 Source does put out a lot of good products for us, but this housing & pump assembly is deffinately not one of them.
