Quote: Ben Snobar had a 4bbl T/A air cleaner like the one pictured above at Carlisle ~5years ago. Same one? Reproduction?
The oval air cleaner will not clear the A/C compressor, so maybe the one I have is as correct as I'll get? Galen said the only other one he's seen was at Papa Dodge.
Jack, got any pics?
Ben sells them as two piece..very easy to tell. His outer ring has 7 stamped holes to fit over the seven studs that he leaves in the 4 bbl base...and includes the 7 oblong washers and nuts usd with shakers. Plus his 4 bbl base has no drain tubes as an original would have. If the one at Carlisle was that way you could spot it a mile away. One that was destined for production would have the same amount of spotwelds___ in the same location as an original TA base. Even the repro TA bases haven't got that right....yet.
