What application is this for?
two wire or 4 wire resistor?
points or electronic?
I am running an orange box with a 4 prong ballast. Only the bottom two posts of the ballast are being used. It has run like this for a long time.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
