Well, I swapped to another ballast and vroom, it fired up. Ran for a while, then shut it off and restarted several times. No prob. Eventually, I got it to not start again, this time, not even when in the start position. Nothing. I did notice that when I would turn the key off, the ignition would spark, as the carb would backfire from it. Eventually, after sitting, the motor fired up and ran some more. I went out this morning before work and tried to start it again. No luck and this time, it is back to running in the start position, like a traditional ballast issue. What the hell? Looks like I will have to replace another ballast before I even begin to troubleshoot more.
I did notice that while running, the ballast was very warm.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
