Quote: You referring to an idle stop solenoid? This Carter will not idle hot or cold. You have to be pumping it fuel. I thought it was probably plugged with dirt somewhere and the soak during rebuild just didn't get it all for some reason.
No, look on an exploded view. The compensator is a little air valve that opens when the temp comes up, a controlled vacum leak. Sits between the secondaries.
