i need to check out the archives, i thought i saw a 500hp 440 build in there a while back..
I have a 500 HP, 544 Ft Lbs torque , in my garage now for sale. It has a set of ported big valve 906 heads,Comp Cams XE284 HL cam and lifters, RAS 1.6 Ductile iron rockers, Manton sereis 3 3/8 x .084 pushrods, Speed Pro pistons and file to fit rings, 9.44 to 1 comp ratio, LY rods and ARP bolts, stock forged steel crank with .017 increase stroke Eddy RPM Performer intake with a Holley 950 HP carb,Moroso 4 hole one inch spacer, 1970-71 Hemi/440 6 pak oil pan and pick up with a homemade crankshaft scraper. nothing exotic Use that combination if you want I had that motor in my Duster(3400 LBs. with me in it) for one weekend at the track, it went 11:30s at 119+ MPH spinning the tires
