Quote: Thanks for your input guys. I feel a little better bout this. Now time to spend money else where!!!
Remember that most of the carbs are running a .110 needle and seat per float(some are only a single .110 needle and seat).... alot of times you would be better to go up in the needle and seat size as in a .120 or .130 If you can jet up enough to slow the car down(MPH) you are getting enough fuel... if it does slow down when jetting up I would change the needle and seat first before buying a pump or changing fuel lines but bigger will NEVER kill your engine like a lean condition will
