Did I put them on right? I wasn't too sure if the grey boot was different than the black boot or not. I put the grey boots on the distributor end since they were a little smaller and took up less space there.
Streetwize - yeah I suppose a bigger cam would make more power but this is supposed to be a street type buildup and the torque curve is supposed to start at 2500 rpm. In fact, depending on how this test goes I might pull the roller out and put a big hyd flat tappet in there just to see what a super low maintenance motor would do on the pump.
