on jack stands trans shifted fine....on the ground ....no had to rev engine to get it to even move at all. ouch. looks like we have a bad torque convertor...so out it comes ....trans taken to John at CRT...he check it out,pump,valve body,drums...everything is ok...sending the torque converter in TO GET IT CUT APART AND SEE WHATS FAILED...
