Aquired a 1972 360 core, tore it down,hot tanked,deck checked,align bore checked, block was bored .030,crank was cut 10/10, new Eagle I beam rods&Coated 9.1 Speed Pro pistons were aquired,B&M 904 Flex Plate, assembly was balanced,also added to the Nostalgic pile a Nos DC 525 mechanical cam&lifters,Sig Erson pushrods,DC Tach drive,electronic,mechanical advance distributor,double roller chain and gear set,hd pinned oil pump drive shaft,Offy port-o-sonic intake,2.02 915j heads....etc etc...
