5/06 more progress...distributor in,spark plugs in,wiring harness installed,voltage regulator,ballast resistor,oil pressure gauge in,temp sender in,went with Auto Meter electric water temp gauge...no where to plug in my nos moon mechanical water temp gauge...no threaded hole big or deep enough in that manifold...looks like i will mount MSD6C inside under dash,Mount mallory coil to left and below ballast resistor.removed entire heater box assembly, now got two nice holes to run wires thru....have to get some grommets...
