We are using the Edelbrock Pro Flow. It was around $2600 but we did the higher HP set up. I think there was an up to 400hp set up at the time for a lot less.
That one in Hot Rod sounds like a sweet set up. Especailly the fact that it is self tuning to a certian extent.
No matter what you use, it will sure help out in reliability. We are still contemplating installing one in the "71 Vette just for that reason.
Here are few pix of when we installed it.
EFI Instal A few more A~
