remember to cut off those ears .Also the 727 big block and 727 small block look almost alike except the bell housing bolts are spaced apart a little .All those 2 piece trans bellhousing are crap even with a tunnel .
Watch the 904 jw bellhousing you have use a 727 ring ask me how i know
CSR
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
