If you get a billet drum in there ... just use the MINIMUM "protection" that is required. You do NOT need that super-high-dollar and/or fancy-stuff since with the special-drums there is no possiblity of the trans ever coming apart.
If it's man-made, then there's always the chance of failure. Saying there's no possibility of it ever coming apart is ridiculous.
I'd much rather have the CSR shield than a blanket. CHIP
