Not that it can't work, but you are in a long list of guys that have faught with the Eddy 750 off-idle stumble. Do a search on it, you'll be amazed. I tried every setting and rod / jet combo immaginable. Tried two different carbs, same issue with both. Went to a Holley 750, Sooooo much better.
LemonWedge - Street heavy / Strip ready - 11.07 @ 120
