OK, im back with some more numbers.
First off I did manage to get my floats adjusted, I had to turn the front adjuster about 3/4 of a turn in to get fuel to stop running out of the sight. It doesnt seem like that really changed anything yet though.
Im now at 15 degrees of initial timing, pulling about 11 inches of vacuum at 850rpm. Is that what I should be seeing with the bigger cam?
So whats my next step?
