Re: Ring packs, gas porting, vacuum pump questions
[Re: AndyF]
#3183236
10/11/23 09:57 PM
10/11/23 09:57 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Thinner rings and a vacuum pump can add 50 hp to a race engine but the rest of the engine needs to be able to support another 50 hp. If you have good heads, the right cam, a good carb, etc. then sure, you should pickup some power.
If this is a dedicated race car then you might want to think about adding compression at the same time. For bracket racers I always recommend picking the CR according to the fuel that you can most easily find in your area. Usually 112 is available also everywhere so if that is the case for you then match your compression ratio to what works well with 112 and the engine should be happy for a long time. Nowhere that I have lived or raced have I ever seen 112 available except at a track, or in pails/ drums from a fuel vendor. On the other hand, 110 is readily available at the pump at a number of gas stations. Seen it available at the pump pretty commonly most everywhere. 112. Never.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
Entire Thread
Mbrown
10/11/23 11:42 AM
dvw
10/11/23 11:54 AM
340Cuda
10/11/23 03:39 PM
Al_Alguire
10/11/23 04:33 PM
AndyF
10/11/23 05:13 PM
6PKRTSE
10/11/23 06:11 PM
LA360
10/11/23 10:56 PM
B3422W5
10/12/23 01:57 AM
Cab_Burge
10/12/23 06:17 AM
Mbrown
10/12/23 10:47 AM
Al_Alguire
10/12/23 04:28 PM
HardcoreB
10/13/23 01:31 PM
Mbrown
10/13/23 08:18 PM
AndyF
10/14/23 12:41 AM
Mbrown
10/14/23 11:35 AM
Cab_Burge
10/14/23 05:07 AM
Mbrown
10/14/23 11:56 AM
Al_Alguire
10/14/23 04:02 PM
451Mopar
10/17/23 09:12 AM
6PKRTSE
10/18/23 03:00 AM
cudaman1969
10/18/23 02:40 PM
dvw
10/18/23 05:30 PM
Al_Alguire
10/18/23 05:49 PM
cudaman1969
10/19/23 12:43 AM
