I called Joe Lease at NHRA for clarification.
Two things.
1) The 8" rule is measured from the main hoop. It does not need to be measured along the angle, and especially in a case like this with the B-Pillar so far forward on a 4-door, they said no problem.
2) With the A-Pillar bar landing on the side bar, they had no problem with it as it's almost on top of the floor joint. I'm not sure how far they would let you pull this back, but in this case they had no issue.
I appreciate everyone putting eyes on it though. First and foremost I want it to be safe. Second I want to make sure it'll pass!!!!
