Getting ready to purchase a replacement radiator for a 70 E-body 440 with A/C. This combo can test a cooling systems ability to maintain proper cooling. Already have a good fan clutch and fan shroud. 2 decisions to make. Which is better,
2 rows of 1" tubes?
3 rows of 5/8" tubes?
4 rows of 1/2" tubes?
Also what is the best material? Aluminum or Copper/Brass?
Thanks Group!!
You don't typically get to pick both tube size AND material. Larger tubes are almost always aluminum (stronger material), while the smaller tubes are typically the copper/brass. Aside from just comparing tube size, you need to look at tube spacing and number of tubes. At the end of the day, you can get a lot of heat to the radiator,
but if the airflow isn't there, the heat doesn't come out (More tubes and less fin = more pressure drop on the air side for the fan to overcome).
Pick a product from a proven, quality supplier (Glen Ray, Griffin, etc) and you'll be fine. It all comes down to the look you want in the car too.
