U.S. Radiator relocated to Arkansas (from Calif) a few years ago.
I purchased a 22" "Triple Flow" aluminum radiator (with two 1.25" rows) from them... appears as a stock factory radiator (upper and lower tanks).... I have a 22" core opening.
I have no problems while regular driving, however, under ~20-30 minute road race lapping ... and extreme pylon autocross competition (lots of autocross runs at MOPARTY!), the engine runs hot... I intend to install one or two shrouded electric puller fans (replacing my aluminum 7-blade clutch fan and factory shroud)... hoping that will help... especially during long runs and in-between runs. I've tried running 160,180 and 195 thermostats... no difference with the hi-heat issues when racing long periods of time. I'll typically turn on the heater full-blast to reduce the heat when racing.
I'm also going to make and install an upper flat shroud.. grille-to-core-support... as I see on all road race cars at various tracks.
