Yea thanks man i know it can be a little hard to keep track. I tested it with the primary wire on and off and neither one worked so i guess iell try it with a new coil and see what happens. when i turn the key to the run position where should the needle on the ammeter be at? because it looks like it dips below where it normally does but i cant be certain.
