Not nec, could require the total load, maybe, notice that the wire is discounected to the alternator when you remove the second plug.
So it is possible it is alternator. Reconnect everything but remove the connection to the alternator.
After you figure everything put a new end onto the fusible link. it will hold better with the correct terminal.
