the bracket.
Pic 1, The holes on the inner fender. The oblong hole on the right was the original hole. After the bracket was tack welded together, I put it in place, bolted to the the inner fender, and clamped it to the firewall, and marked the left side hole. Then I pulled the inner fender away far enough to drill the left hole.
Pic 2, The bracket set in place after the holes were drilled. The bolts are in the holes to be sure everything was going to be in the correct position.
Pic 3, The bracket bolted in place using the U-nuts.
Pic 4, The final step with the bracket, welding it in place.
