I was looking into buying this rotating assembly 1-98111BI - Scat Engine Rotating Assemblies
Summit Scat KitNot sure if it would run on 87 with Edelbrock 63cc heads and Felpro 1008's, Voodoo 60403 226 int./234 exh.
I have a 416 stroker with Edelbrock heads “63 cc” that we cc’d at 65 +/-1 cc. And 21cc Icon dish pistons with quench pad. Measured at 9.7:1 compression. It less than .035 quench. And has all chamber edges or potential hot spots deburred including chamber matched to bore. I have the older Comp 274-S cam with 236/241 @050 and .502/511”
I can’t run 87 octane. Maybe if I dialed timing way back.
