Quote: BUT with proper springs ... there will be no wrap-up ...and the pinion angle should not move anymore that 3-5 degrees at the most.
As many chassis builders have said ... a PS is just a band-aid for INeffective rear springs.
Yep - pinion snubbers are just a waste of time and effort and money, and pure garbage/crutch. Ask some of the race guys.. Buy good springs and install them and you will eliminate wheel hop. DAMHIK.
